MPC 3500 error sc 547
  • Rick
    • Mar 2007
    • 277
    This unit has a sc 547 code I looked in the 5 mode for a reset method and cant find any does any one know how to fix this ?
  • teebee1234
    • Jul 2008
    • 1670
    Same as all the other Ricoh's that require an SC reset > 5-810. If it reoccurs, you may have a bad power supply.
    Zero cross error
    • Defective fusing relay
    • Defective fusing relay circuit
    • Shorted +24V fuse on the PSU
    • Unstable power supply
    1. Check the power supply source.
    2. Replace the +24V fuse on the PSU.
    3. Replace the PSU
    • rsyarcia
      Hair Straightener Tech
      • 711
      SC 547 with MPC 2550,MP4500 etc, our circuit technician was able to repair the PS by changing capacitors.
      Nobody is perfect..
      • CT Copier Repair
        • Mar 2010
        • 304
        BAd caps on PS
        or cold solder joints POS Ricohs
        • Rick
          • Mar 2007
          • 277
          The machine was just moved and the power supply board was cracked. Thanks guys I was able to repair it . good advice.
          • TonerMunkeh
            Professional Moron
            • 3865
            CRACKED? That machine must have taken a hell of a hit!
            Hit it.
            • Gift
              • Mar 2011
              • 2459
              I recall having a broken PSU after transportation by an external moving comapy as well - bad luck if the handling was too rough. On the other hand there are quite some heavy components on the PSU - that reminds me of the A1045 series PSU, back than we received quite a few brand new but damaged OEM parts because the box/cushions design wasn't very well done for shipping.
              • Rick
                • Mar 2007
                • 277
                The power supply is very big and not very well mounted . I can see this happening again.
