MPC 4500 deleting administrators password . Unable to program IP address
+ More Options
Posts
  • Rick
    • Mar 2007
    • 277
    There is a password set in this unit and I cant make any changes to network. Is there a memory erase function that I can perform in mode 5 to clear this?
  • nmfaxman
    • 1702
    Try logging in as Supervisor with no password and change the admin password.
    If you can't log in as supervisor you will have to replace the novram.
    • teebee1234
      • Jul 2008
      • 1670
      Try logging in as "supervisor", leave password blank. From there you can go to Administrator Management and reset the login and password, you can't make any other changes in supervisor mode. If supervisor login has been changed from default and the new one isn't available, then the NVRAM will have to be replaced.
      • Rick
        • Mar 2007
        • 277
        It worked . Thanks guys
