Ricoh CL7000 Black Spots
  • gcawad
    • May 2025
    I am getting 3 black spots about 1/3 down on the page than run across the page in a line.
    Thanks for any help on what needs to be replaced.
    Gary
  • mikadonovan
    • May 2008
    • 2931
    Sounds like you might have a ding in the black drum surface. Time for a new PCU.
    NEVER ASSUME ANYTHING
    • gcawad
      I am going to repost this under the printer forum rather than the copier forum.
      I checked and this is what I replaced just 5K copies ago; it was doing it before and after the new Photoconductor Unit (Type7000F). Any other ideas what this could be?
      • teebee1234
        • Jul 2008
        • 1670
        Can you post a sample? Also, does the pattern shift up/down the page on subsequent copies? Run an 11x17 sheet through and measure the distance between repeats, that will give you the diameter of the failed component.
