Ricoh Aficio 3045's Document server not functioning
  • xlbizs
    • Jun 2009
    • 66
    Dear all, I have one unit Aficio 3045 with print/scan & fax,
    - Network Printing, Scan to SMB, FTP no problem.
    - the copier still can print/copy two sided output.
    - BUT, Document Server Not Functioning & Store File function not appear at the Scan sect.
    - no document server at the WEB image Monitor.
    Try change HDD (From Aficio 1035) with Fomat All at the SP mode. still same.
    any solutions & all ideas. Thank.
  • jonhiker
    • 661
    It sounds like the Doc Server function is disabled. Check in sp mode to turn it back on: SP#5-967-001 needs to be set to 0, then reboot.
    • xlbizs
      • Jun 2009
      • 66
      Thank Jonhiker, thing done, all functions work and customer happy.
