So when ever i do a print out on 11x17 80lb cardstock through the bypass tray, the machine gets the paper in about 5 inches and then jams. I have not been able to get one successful printout since this started happening
Ricoh 3260 Paper jam
Im not familiar with this particular model, but have had something that sounds similar on a mpc7500. The customer would use pre printed cardstock (a4SEF mind you) which had a black triangle on the front that lined up with an optical sensor triggering a jam, any other media would fly through that bypass without missing a beat, but ya couldn't do even one with the pre-printed stock.
I could come up with no other explanation, there were no "hit" marks on the edges of paper, machine would just stop transport and trigger a jam.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison -
