MPC2050 - problem line
  • hmac
    • Aug 2009
    • 129
    I have on my mpc2050 black lines that appear on
    pages.
    Copies B / W: 3 black lines
    Color copies: 1 line every 13mm on all the
    page
    I change the optical unit which is under the drums, the hard disk and RAM strips.
    The copier in one week.
    The lines are copies and printing.
    _________________
    HMac.
    _________________
  • rsyarcia
    Hair Straightener Tech
    • 711
    how many copies this machine has? you have to clean the charge rollers
    Nobody is perfect..
    • hmac
      • Aug 2009
      • 129
      100 color copies
      200 N/B copies
      CHarge roller is clean, the machine one week.
      _________________
      HMac.
      _________________
      • rsyarcia
        • 711
        can you print the test pattern and post it here
        Nobody is perfect..
        • kopirmaster
          • Apr 2011
          • 70
          cheka up laser unit,
          • brodera
            • Aug 2009
            • 106
            Check the scanner glas and the moving Mirrors.
            • hmac
              • Aug 2009
              • 129
              I change the laser unit is always the same.
              _________________
              HMac.
              _________________
              • hmac
                • Aug 2009
                • 129
                This is not the scanner because I have also the problem when printing.
                _________________
                HMac.
                _________________
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  I think your next step is the controller board. Make sure you get the correct one though, there's 4 different ones.
                  Hit it.
                  • hmac
                    • Aug 2009
                    • 129
                    Here is an example of my failure
                    _________________
                    HMac.
                    _________________
                    • brodera
                      • Aug 2009
                      • 106
                      woooow... humm.. have you checked the paper before it hits the fusing unit? make a print and then open the left side and cause a paperjam manualy before it hits the fuser (Can be tricky)
                      Also check the transferbelt and ITB after that.
                      //Best Regards
                      • hmac
                        • Aug 2009
                        • 129
                        I find the problem!
                        It's the controller board is defective. I replace with a new one is his work.
                        Thank you for your help.
                        _________________
                        HMac.
                        _________________
