MP 4000 Cleaning Web Assembly
  • Ricoh-ono
    • 338
    I know these machines were notorious for the hex screw stripping out. Ricoh updated the hex screws to help prevent that. These assemblies are costly when they have to be replaced. What tools are any of you using to extract the rounded out screw?
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    I've used my star drivers with success.
    There is a great post on here to mod these fusers with an oil roller rather than replacing the web. Doesn't help with getting the hex screw out, I know, but ya wont have to worry about it next time.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      Look at KATUN: they have a special (german manufactured WIHA) tool espacily for the 5,5mm RICOH-Screws.Use it for years no more problems with the screws.
      Greetings...
      • jonw
        • 57
        I've got a machine out there thats done 600k on original rollers without a web unit fitted. No jamming problems.
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          I had to leave one without a cleaner for a weekend until I could get the parts I needed and did think when I returned and had a look at the condition that these were not needed. Customer printed 20K that weekend, not quite 600K I know.
          • totoro
            • 568
            I have never stripped one out so I haven't had to find a tool for that problem but, a co worker says he has had to get his Dremmel tool out and cut off the shaft with the screw on it.
            Totoro
            • Ricoh-ono
              • 338
              Thanks everyone for their posts. I'll let you know what ends up working for me.
              • jonw
                • 57
                We have lots of them running without cleaner units. For a small dealer Saves a lot of time and money , which compensates for the s**t dev life they have.
                • rthonpm
                  • Aug 2007
                  • 2849
                  What you can do to extract the shaft with a fused set screw is cut the web off and remove the bushings and E-clips on the opposite end, as well as the ones on the side with the gear and set screw. it's cheaper to carry a new gear and bushings in stock with a bag of the new style set screws shared between a batch of techs than it is to keep buying web units all the time.
                  As many people have said over and over, this is an incredibly over-engineered piece of garbage anyway. Why not something as elegant at the MP 6000 web???
                  • seansbar
                    • Dec 2010
                    • 198
                    We let the web run out, reset the message, break off the web end sensor flag. Then run the machine without a web. They all seem to fun fine, and the HR life doesn't to seem to suffer at all.
                    • tcs04
                      FORMER Techie
                      • 1183
                      And if the above solutions (All good) don't work, there is a modified screw!
                      • patswk
                        Another approach make sure the unit is fully cooled (if possible) and use either a battery post puller or gear puller (clunky but effective) the gear and screw are reusable and if you you dont crank down on the screw you should be good
                        • Masterchief
                          • Apr 2011
                          • 280
                          if anybody finds the mod for replacing the web with an oil roller could they pm me please with the link
                          sigpic
                          • teebee1234
                            • Jul 2008
                            • 1670
                            Here you go....
