Hm... show should work, i never did try on that model, maybe it has something to do with that...
The set http works as it should...
Try print list in interface settings, it is the same as the show comand.
if you are doing it remotely,trough telnet you can also try to get web up by typing: set web up
If you are still unable to access it. Make sure to go into administrator tools under systems. Make sure the network security setting is set. Must be logged in as admin.
Thanks for your reply.
Can you give me more details? What do i have to see under network security?
