How do i replace the developper unit on the MP 9000?
+ More Options
Posts
  • idplus2
    • May 2011
    • 19
    Hi everybody,
    Can you please tell me how to replace the developper unit in the mp 9000?
  • flo
    Engineer
    • Mar 2009
    • 44
    what is your Problem to change whole unit?
    • idplus2
      • May 2011
      • 19
      NO, i just would like to know how to use the little bag with powder ,unit #B2349640
      • flo
        Engineer
        • Mar 2009
        • 44
        for changing Developer (Bag) you have to take out the developer box .
        after opening the Transfersection u can turn out the Drumsection pull up developement section
        and take it out to right side than u have to trew away the upper section Two Screws and dont forget conector also one screw. take out old developer and clean the magroller so its like silver after finish take in developer and after rebuild u have to make the initalization for Developer SP Mode
        after this u must have a dark contrrast Picture
        But i rate u to read a SERVICEMANUAL before u l'do this work at first Time because normally this light Pics coming up near PM Level and u have to do more things to clean and solve some Problems
        • teebee1234
          • Jul 2008
          • 1670
          I'm sorry, but if you have to ask then you really shouldn't attempt it. I don't know what your situation is, but get a trained tech to do it. Maybe he/she will let you watch and learn, but you will most likely do more harm if you do it yourself.
          • idplus2
            • May 2011
            • 19
            Thank you
