Password Change on MPC2050
  • brodera
    • Aug 2009
    • 106
    Hi!
    I just got a call that they cant scan to folder. I went there and saw that the folder path was totaly wrong. logged in via web monitor and typed in admin, Authentication fail.
    then i tryed logg in as supervisor, Authentication fail / wrong password......
    This costumer has no internet connection what so ever due to secutity reason.
    The costumer cant even handle a computer, so i doubt that they have change it.
    What can i do? beside change the NV-RAM.
  • TonerMunkeh
    Professional Moron
    • 3873
    How have the passwords been changed then? Unless supervisor works the only thing you can do is change the NVram. Bill 'em!
    Hit it.
    • brodera
      • Aug 2009
      • 106
      Well.. as i was saying, there is no way that the guys at that company can change the password. Prolly some rival company that did this on a visit...
      well well. thanks for info TonerMunkeh
      • teebee1234
        • Jul 2008
        • 1670
        Just for goofs, did you try and login to User Tools on the device itself?
        • brodera
          • Aug 2009
          • 106
          Yeah, but the machine does not respond when i press the KEY button, so i guess that it dosent have any password on it.
          • zed255
            How'd ya manage that?
            • 1025
            You can try performing an NCS clear with 5-801-11, and generally OK to do 5-801-10, 14, 15, 20 if the NCS didn't help. Just don't do a full clear. Did you say you can get in via the OP? If so the admin authentication isn't likely on and it will be just the WIM that shows a password being set.
            • brodera
              • Aug 2009
              • 106
              Got it solved by manualy type in the IP-Adress and then use the Auth info.
              The password thingy is still a ghost story
              Thanks for good replys! Reps to ya all!
