Ricoh aficio 1075 end temparature display
  • georgereth
    • Jul 2009
    • 47
    This machine is working only with the center thermistor
    i go in the sp mode 1105 and it shows me only the adjastment of the center thermistor. The end thermistor is not in the adjastments.
    The same is in the sp 1106 (fusing temparature display) its display only the center temparature and not the end temparature .
    All the other sp settings & programms are as the other machines
    any ideas for this problem ?
  • teebee1234
    • Jul 2008
    • 1670
    The 1075 is a B065 and doesn't have and end temp adjustment. The 2060/2075 (B140) does. What's confusing is they use the same service manual.
    • georgereth
      • Jul 2009
      • 47
      Yes thaths correct about the adjastment .
      But i have still the problem that in the sp 1106 (temparature display) shows only the 001 center thermistor and does not show the 002 end thermistor temparature display
