Win.server2008 conection
  • bostjanma
    • Aug 2025
    Hi all,
    costumer change server from Winserver98 to Winserver 2008 (version 2011) 64Bit. After that they have problem with conection to the shared map on that server for the scan to the folder. The multifunction is A2045.
    My question is; if we have problem with 64Bit Win.oper.system? If I save the problem with upgrade or copier does not support 64Bit server? My be any other adjustments?
    On the old server we don't have any problem to conection. We copy addresbook with the same data.
    THX
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    I think the machine is too old. Theres been a few posts on here regarding those older boxes and win 7.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • rthonpm
      • Aug 2007
      • 2859
      The machine is too old for the newer NTLM and SMB versions used by the server. Time to retire the machine anyway, the whole 2045 series wouldn't have been able to natively scan through SMB anyway.
