Removing the Fiery E-7000 from a 3260c
  • Ricoh Dicoh
    • Dec 2010
    • 62
    Were having interface issues with this E-7000 and we need to take it back to the shop to work on it, but we don't want to leave the customer down. So the issue is that when we disconnect the fiery the printer feature is gone. No printer sp, as is usual when the fiery isn't on/connected. So what we want to do is restore this machine back to a 3260 without the fiery. Enabling printing without the Fiery. Is this possible?
  • rthonpm
    • Aug 2007
    • 2859
    You will need to re-install the Print/Scan card. As the fiery replaces all of the internal printer functions you can't keep the card in the machine. If the machine was properly installed, then the SD card should have a happy little home somewhere in one of the nooks and crannies of the machine.
