1027 PCU fail
  • ponto700
    • 144
    1027 PCU fail
    Hi,
    ON 11th April i put in one machine a new pcu (1027) and today client fone me becouse copys was coming out half light and half fine. i went there and i print the counter and the result is the file attached.
    i try to reset again the pcu but when i do this i get sc329. i went to the values and i check vsp/vsg and vsdp value are 0.
    i remove the pcu and i put in one other machine and i get the same problem. this pcu dont make more than 20k copies and is feiling. what can be the cause of this? tomorrow i will dismantle the pcu and check what is wrong! can be the td sensor demage and is causing this values to 0? for me is really strange this...
    thanks to all.
  • Eric1968
    • 2458
    Replace the PCU and try to claim the one that's causing problems.
    • ponto700
      • 144
      the problem Eric1968 is that i order from overseas. and i cant claim becouse i will spend to much just to send this one back. do you have any ideia what can be causing this?
      • Masterchief
        • Apr 2011
        • 280
        what machine did you put it into,
        sigpic
        • ponto700
          • 144
          • Masterchief
            • Apr 2011
            • 280
            We have had a couple like that, but we had a local supplier and able to return them, in some cases i believe that the developer goes off after a prolonged period, due to it being on the shelf the last 5 years or more i guess, have you a dev type 18 you can use to try fix this problem
            sigpic
            • ponto700
              • 144
              yes, i have type 28. i will change the dev tomorrow to see if the problem is fixed. thanks.
              • Masterchief
                • Apr 2011
                • 280
                its dev 18, type 28 dev is for ricoh 3025/30 the black handle pcu
                sigpic
                • ponto700
                  • 144
                  im using dev 28 to rebuild the 1027 pcus ( i have rebuilded more then 50) and also for 2020 and 3025 pcus.
                  • CableGuy
                    Impulse Drive Engineer
                    • Oct 2008
                    • 417
                    Have you cleaned the lazer slit glass?
                    • dv007833
                      • Aug 2008
                      • 43
                      There is a possibility that you've bought an imitation PCU and thus is now causing a problem. Check with your supplier or with Ricoh directly to check its authenticity.
                      • dfs
                        • May 2011
                        • 25
                        Possibly an dodgy PCU. The PCU product code should be 411018.
