Toner
  • CrapAimer
    • 296
    Toner
    Nashuatec Dsc 428
    Black Toner Light not going out replaced toner and black dev unit.
    HELP
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • Jomama46
      • 2900
      Replace the black pump, above the dev unit.
      sigpic
      A+; Network +; PDI+
      • CrapAimer
        • 296
        will do thanks, looks like a lovely job.
        • teebee1234
          • Jul 2008
          • 1670
          If you haven't done it before, it is actually quite easy. Pull the ITB and the pcu's and you'll have easy access to the pumps. Pull the wire connector for the pump from the top of the inside frame and ease off the toner hose from the pump nipple. Remove the 2 screws that hold the pump and pull it out.
          A couple of things to keep to keep in mind, the black and yellow pumps are interchangable with each other (hose nipples are at an angle) as well as the cyan and magenta with each other (hose nipples are vertical). You won't need the hose that comes with the new pump (unless the current hose is plugged and can't be cleared). Be sure to route the wire connector in the clips against the rear, I've torn them off when inserting the ITB because I didn't secure them properly.
          • CrapAimer
            • 296
            Many thanks all, changed pump working a treat now.
