Hey guys,
I have a client who has a Ricoh 3224c (I know I know...) with about 11k copies on it. They use generic toner in this machine (a big no no) and now the yellow toner says that it's not set properly. They ordered a new yellow toner and the same thing happened again with no change.
Here are the things that I've done. I cleaned the optical sensors in the development unit. I checked and made sure that the developer has toner in it (it does). I made sure that the augers turn when the machine is adding toner (it does). I made sure that all gears in the developer unit are working as they should (they do). I made sure that the connectors all have 4.6-5.0 volts coming from the distribution board (they do). I tried swapping the cyan and yellow developer connectors and it still screams for the yellow to be replaced. No matter which connector I connect to the yellow, it still says to replace the yellow toner.
I am at a loss here... Does anyone have any suggestions? Thanks
