Aficio MP C4000 Print issues
  • iscott
    • Mar 2010
    • 344
  • totoro
    • 568
    Have you tried updating the firmware?
    Totoro
    • tonnerboy
      • May 2011
      • 212
      Did you saw the printer driver properties?
      Maybe User codes authentication...
      • teebee1234
        • Jul 2008
        • 1670
        It sounds like they have a corrupt print job in the queue that needs to be cleared. Disconnect the device from the network and print to it from your laptop. If all goes well, plug it back into their network, if it hangs then the onus is on them to clear it out. It wouldn't hurt either to update the firmware too, as totoro suggested. As far a user authentication, if the driver providing the print job doesn't have the correct code then the job should just disappear. You may want to turn off user authentication and test it that way first.
        • iscott
          • Mar 2010
          • 344
          Firmware has been upgraded. I agree with the corrupt print job idea but they are using mostly macs and they ‘claim” there is no such thing as a corrupt mac print job.
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            Are you sure there is a PS option in the machine? If you print the printer config page out it should show it in the top section. You can also use Gutenprint for using PCL drivers on non PS equipped machines, but it's not supported by Ricoh.
            • TonerMunkeh
              Professional Moron
              • 3865
              Originally posted by iscott
              There is no such thing as a corrupt mac print job.
              And what a load of crap that is!
              Hit it.
              • rthonpm
                • Aug 2007
                • 2859
                Much like the old saying Macs don't get viruses!
                Mac OS X Viruses: How to Remove and Prevent the Mac Protector Malware - How-To Geek
                Try doing a Job Reset for all jobs from the op panel in printer mode, or try clearing the printer settings in SP. Also make sure that Error Reports are turned on in case there's an issue with a job that keeps screwing the machine up: that way you have something to go on with which side of the machine the issue is on. If it's a continuous problem, maybe also allowing Auto Continue would be a good idea.
                Also make sure the PostScript firmware is up to date along with the printer firmware.
