Mac printing mp171spf
  • stig
    OVERWORKED..UNDERPAID
    • 52
    Can anyone tell me if the gestetner mp171spf will print from a mac laptop or does it need the postscript option installed.?
  • tonnerboy
    • May 2011
    • 212
    For all the funtions you need the PS.
    But... Go to this web page and take a look:
    Gutenprint for Mac OS X
    • zed255
      How'd ya manage that?
      • 1024
      +1 for checking with Gutenprint. Failing that then postscript would be needed.
      • mrwho
        Major Asshole!
        • 4299
        Re: Mac printing mp171spf
        I also got a customer to print with Guttenprint. I believe on newer versions of MacOS you don't need to install anything - it should do it right out of the box.
        Mascan42
        Ibid
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          A few things about the Gutenprint drivers:
          1). Not all models are supported. I found that out when I needed to print from the "forgotten" Mac notebook to a Ricoh MP C2050.
          2). Not all features are supported, as Tonnerboy mentioned. I ran into this with a customer who had his one Mac set up with Gutenprint drivers, and he was happy. Then along came the need to add Ricoh "user codes" so as to track and control color printing. The Gutenprint driver didn't support user codes - it got a little ugly.
          3). Performance will likely be much slower, and color output may not be what you expect.
          and
          4). No manufacturer will support you if you go down this road. AFAIK, they will all tell you " PostScript or nuthin' ".
          • mrwho
            Major Asshole!
            • 4299
            and
            Of course. If your customer needs to use any advanced feature (like, for example, user accounts), you need to sell the PS option to the customer.
            Mascan42
            Ibid
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Trouble is, the customer who is too cheap to get real PostScript to begin with is the same one who wants to restrict color usage using codes!
