Error message in MPC300
  • tonnerboy
    • May 2011
    • 212
    I changed a Nvram controller and now comes a message saying: "this software can not be installed again. It has already been installed on other equipment. "
    I got notice that this message is associated with DOS SDCard. Because when i take out the SDcard the message disappeared.
    I followed all the procedure that was in the manual to change the NVram of the controller.
    Is there any procedure that I had to do before changing Nvram? I still have the old Nvram. Can I still do something?
    Please help! Thanks
  • rsyarcia
    Hair Straightener Tech
    • 711
    Replace the SD card and NVRAM if any of the following
    occurs:
    SC866 and SC868
    �� ‘This SD card is already installed’ appears on the display
    Nobody is perfect..
    • Eric1968
      • 2459
      When you replace the NVRAM you also have to replace the DOS-Unit.
      • tonnerboy
        • May 2011
        • 212
        Thank you guys.
        He liked to understand ... This happens because the data are hosted in the Nvram of the controller?
        Like I said, I still have the old Nvram. If i make the backup and then restore the new Nvram will it pass the DOS data to the new one?
        Sorry if i am annoying but i saw this on TESSA:
        Question: What to do with the DOS option when one of the following parts is replaced?
        Answer NOTE: Please ensure that a DOS option can be installed on your particular model.
        Controller NVRAM
        Q. If the NVRAM from the controller board is replaced, can I reinstall the DOS unit?
        A. The same DOS unit can be reinstalled.
        This is not for this particular model but for all models that can support DOS
        My question is: Is this possibel? If so how?
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          You may have to reinstall the old NVRAM and deactivate the DOSS feature? I haven't seen this yet, but I do know you have to enable it in tech rep mode and disassembly is the opposite of assembly, right?
          • tonnerboy
            • May 2011
            • 212
            First I want to thank you all the help.
            Already managed to get the machine working.
            I put back the old Nvram and did the upload to an SDcard. Then I put back the new Nvram and copied the data there.
            And its done... No more message.
