Ricoh 3245 and 3045 firmware levels
  • nmfaxman
    • 1702
    Does anyone have the firmware History for these machines?
    The latest I have is 2009.
  • TonerMunkeh
    Professional Moron
    • 3865
    Which firmware are you after?
    Hit it.
    • mikedci
      • Jul 2010
      • 227
      rfg019271.pdf
      rfg020297.pdf
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        3045 last update
        BICU/BCU 1.27.07 19-4-2007
        Browser 1.40 27-5-2008
        Controller 1.39 30-12-2008
        DESS 3.00 2-7-2006
        Fax 03.00.00 21-9-2010
        FCU 05.00.00 1-8-2008
        Java VM Card Update 1.41 10-1-2007
        Language 4.03 20-12-2006
        LCDC 1.14 2-1-2007
        NETFile 3.00 28-6-2007
        Network Support 5.12.5 13-9-2010
        Printer 1.15 11-12-2008
        PS3 1.00 6-7-2006
        RFAX 03.00.00 16-1-2007
        Scanner 1.07 2-7-2006
        SR790 5.10 26-10-2010 SR 790 Firmware June 2010 production
        Supports connection for newer models please refer to the release ntoe for exact details
        WebDocBox 1.03 16-10-2007
        Websystem 1.11 28-6-2007
        3245C last update
        DESS 4.00 17-11-2006
        Engine firmware 1.20 12-12-2006
        Fax 07.00.00_LRC0037 10-10-2008
        FCU 07.00.00 5-11-2007
        IPU (3) 6-1-2006
        Language 3.85 12-12-2006
        LCDC 1.07 6-9-2005
        Music 1.05 28-6-2006
        NETFile 2.00 5-11-2007
        NIB 4.20 19-10-2010
        Printer 1.28 5-11-2007
        PS 1.02 6-1-2006
        Scanner 1.09 6-1-2006
        SR790 5.10 26-10-2010 Firmware June 2010 production
        System 1.35 5-11-2007
        WebDocBox 1.07 5-11-2007
        Websystem 1.17 5-11-2007
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Hi, iMind,
          I thought of you as soon as I saw this.
          • iMind
            • Mar 2008
            • 1116
            ... hehehe
            • nmfaxman
              • 1702
              So I have the latest and greatest firmware put out by Ricoh.
              Why can't I do scan to file on Win7?
              I can connect to a MPC 4500 no problem, so my settings on the computer are correct.
              3045 and 3245C won't scan to folder on the same network with all network settings the same.
              Support says the newer machines support Samba version (who gives a rats patoot) to enable SMB.
              Why is there no firmware, other than special order, to make this work?
              I smell a lawsuit for restriction of free trade of both Ricoh and Microsoft.
              What do you think?
              • Herrmann
                • Jan 2006
                • 792
                Dont bother with the smb scan, just get "filezilla server" (freeware) and setup scan to FTP. Works perfect for me
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • ViK2R
                  • 7
                  Older Ricoh devices doesn't support SMB signing. That's why the MPC4500 works. The key here is to disable SMB signing on the client PC / Server. How to Disable SMB 2.0 on Windows Vista/2008
                  But I agree with herrmann, it's much easier or scan 2 mail.
                  Good luck
