Problem about MP2000L2
  • dum_dup_dip
    • Aug 2025
    I've problem with mp2000Le,then I add user from address book in web image and manual key direct from machine.So I press button in machine I can't select destination from shortkey.error is "Destination not found...".But then I print list of address book report has a destination list in paper.Please kindly help me.Thanks
  • totoro
    • 568
    If you are talking about a scan destination. I don't know if this is the same as on the mp171s, but I know that you have to choose whether it is an e-mail or a folder before the shortkey will work. So if the default is for e-mail then switch to folder and try the shortkey again.
    Totoro
    • dum_dup_dip
      Thank totoro.I've been choose scan to folder and email.And insert detail in WIM both email and path.Then I press the short key for machine has a same error log.
      • pradeesh
        • Aug 2011
        • 10
        Re: Problem about MP2000L2
        pls check the converter plate ie changing short key numbers 1-16 and then 16-32
