sc550 cleaning web
  • bcxprint
    Toshiba 210c, 310c, 810
    • Apr 2007
    • 19
    [Error Code] sc550 cleaning web
    Have a ricoh 1085 got sc 550 changed the web, cleared the code still throws the sc550. changed the sensor still coding. Set the 1902 to 0% am I missing something?
  • rsyarcia
    Hair Straightener Tech
    • 711
    if the procedure on the manual cant reset the sc 550, print the smc then perform memory clear(engine). then input the smc data on the machine.just an idea.
    Nobody is perfect..
    • bcxprint
      • Apr 2007
      • 19
      do I dareadmit this? was clearing the wrong 19xx to 0%. lol... obviously in a hurry and it's only Tuesday! Thank you though,. BTW, thank God I didn't reset! The time it takes to reinput all those dam settings! ... always a bright side if you lok right?
      • rsyarcia
        • 711
        that's good!lol
        Nobody is perfect..
        • Mr. T
          • May 2011
          • 14
          somewhere in SP 1902 you might have cleared web near end this will make it keep popping the sc550 code
          • hossam
            • Aug 2010
            • 70
            Enter SP mode then select pm counter then pats list for pm yield indicator then web cleaning roller>>> clear>>> switch off and on
