password bypass
  • copier1
    • Aug 2025
    [Misc] password bypass
    I receive many wholesale Ricoh 3235c, 3245c etc...I have this 3245c that I cannot get through the password screen, I even tried the username (administrator) and no password, and the (supervisor) and then the admin password....nothing! any help out there?
    Thank You!!
  • teebee1234
    • Jul 2008
    • 1670
    If the login with 'supervisor'/password >blank< doesn't work, then you will need to replace the NVRAM. The default on initial setup of Administrator Management is "admin" as login and no password. Logging in as "supervisor" only gives you the ability to reset the Administrators and nothing else. Hence, if someone has changed the default "supervisor" to an unknown, there is no other backdoor.
    • ucinn
      • Jun 2009
      • 383
      Try SP7810 first
      • teebee1234
        • Jul 2008
        • 1670
        Originally posted by ucinn
        Try SP7810 first
        Cripes, you're right ucinn. I guess I was thinking of the 45cpm b/w device. Copier1, ignore my advice and follow ucinn's.
        • copier1
          Password issue
          Thank you both for the advise, I really appreciate it!
