af 1045 blad.
  • iust
    • Jul 2008
    • 58
    af 1045 blad.
    hi
    i change unit drum blad . but my af 1045 has very dark copy on every document !
    sometimes after more than 10 copies apeared sc 350!
    what happen?
  • TonerMunkeh
    Professional Moron
    • 3865
    Is there any reason you haven't put the rest of the PCU parts in? Try that first.
    Hit it.
    • Jomama46
      • 2900
      Probably has to do with the position of the charge roll. Or maybe the erase lamps are covered with toner or not coming on.
      sigpic
      A+; Network +; PDI+
      • ricoh-man
        • May 2011
        • 10
        Check this timing pulley
        • jummamaster
          • Mar 2009
          • 99
          check ID sensor (if there is) and drum grounding,
          Ricoh Error Codes
          Canon Error 5100
          Canon Error B200
          j
          c
          • Gift
            • Mar 2011
            • 2459
            Indeed - he might dealing with a weak drum/dev/non OEM stuff - hard to tell from the initial posting.
