MPC 2800
  • mphile
    • May 2011
    • 29
    [Electrical] MPC 2800
    whats sc 555?
  • ricoh-man
    • May 2011
    • 10
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      The lamp is damaged and i believe there is a firmware upgrade for this once the lamp is replaced. Somthing to do with how the lamp is being switched on has been changed with the new firmware update.
      rtb 41While the machine is in the Standby (Ready) condition, the temperature of the tungsten
      wire in the halogen lamp tends to weaken the wire. If the total time spent in the Ready
      condition is long enough, eventually the wire breaks.
      Upgrade the Engine firmware to
      1.55:09 or later as soon as possible by @Remote
      or at the next service visit.
      The fusing lamp control was modified so that the temperature conditions do not weaken the tungsten wire.
      • Eric1968
        • 2458
        Like Leo34staffs said, upgrade the engine firmware and you'll never see this SC again.
        • techsass
          • Dec 2010
          • 248
          Drop Sp1107 -1 & -3 to 195 degrees then increase -2 & -4 to 70 seconds. Also do the firmware. If you change Sp3904 I would also change Sp2804 to 0 (OFF) to avoid Sc305 codes.
          • mphile
            • May 2011
            • 29
            hi
            thank you gentleman but which lamp because ther are two one is 500/700 w the other is 250w
            • Eric1968
              • 2458
              Originally posted by mphile
              hi
              AX44 0275 Heater 213V/640W (That is if you're in a 220V area). It's very easy to do a continuity check to see which lamp is broken.
              • techsass
                • Dec 2010
                • 248
                Sc555 has bitten everybody who works on these. I've tried the hardware & firmware fixes, but the Sp1107 fix I found on this site is what finally got rid of the problem. Unfortunately I can't find the posts I stol/aquired the attachments from.
                • Gift
                  • Mar 2011
                  • 2459
                  These bulletins are not about the MPC2800
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                    Paul@justmanuals.com
                    • Rich
                      • Mar 2011
                      • 30
                      Blown fuser lamp. Use the lamp for the MPC 2500 to replace it. More reliable. UK part no. AX44 0275. Update the firmware as there's a fix to reduce the current supplied to the lamp. Done this on 40+ machines and never had one blow a second lamp.
                      • techsass
                        • Dec 2010
                        • 248
                        Sorry about that.
