IS200e
  • harwin84
    • Aug 2025
    IS200e
    Hi there, I;ve been facing problem to get this scanner hooked to a pc. I can access the web image monitor, some how when i want to link the shared folder it keeps saying invalid username n password? twain works fine though
    anyone face this prob before?
    harwin
  • mikadonovan
    • May 2008
    • 2931
    Sounds like you need to create a user account with a password on the PC and then input that data into the scanner using the WIM. Should be under folder authentication.
    NEVER ASSUME ANYTHING
    • harwin84
      infact i thought the same too...i did create another user as administrator and allowed full control but it still didnt work
      another question i have in mind. This particular is using scanrouter for a 2045. Can i use the same scanrouter to hook up the is200e as well?
      thanks,
      harwin
