ricoh mp2000
  • tulipano
    • May 2010
    • 124
    ricoh mp2000
    salve ho una ricoh mp2000 , mi da un problema quando vado a cambiare indirizzo ip o entro nel menu utente della copiatrice esce il messaggio " Non si dispone
    dei privilegi per usare questa funzione". come posso eliminare questo messaggio? ho provato anche azeramento memoria ma stesso problema. grazie
    Hi I have a Ricoh MP2000, it gives me a problem when I go to change ip address in the user menu or within the copier comes the message "You do not have
    privileges to use this feature. how can I delete this message? Azerbaijani memory, but I also tried the same problem. thanks
  • rsyarcia
    Hair Straightener Tech
    • 711
    you have to login as an admin.
    Nobody is perfect..
    • tulipano
      • May 2010
      • 124
      how?
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • tonnerboy
          • May 2011
          • 212
          Originally posted by tulipano
          how?
          After you press user tools you click in "login" and than enter the admin with no password
          (like in the WIM).
          By the way, you can do it on WIM. Probably it will be easier.
