Just had a call come in from a customer who is 250kms away. Anyone heard of this SC899 before? I can't find it in my manual.
MPC3501 SC899
found it hidden in a service manual revision bulletin
SC899
D
Software error GW
A software error occurred in the GW controller.Cycle the machine off/on
Update the controller firmware
Controller board is defective
"See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..." -
CrowoodIndustries.com
Are you enrolled in Ricohs @remote programme? when we have a distance problem that is software related, we use a programme called TeamViewer (free for non commercial/trial use) to set up the MFD remotely and then flash the firmware remotely.
Alternativly use the above to manually upload the firmware by logging into the webviewer for the device and upload the firmware that way.
Also please excuse a ply for our website, we supply OEM and compatible toners to the trade at http://www.crowoodindustrie.com/Comment
My manager is driving up there this morning to upgrade all firmware. Since I posted this thread I have found quite a lot of info regarding this SC. I bet it has kept a few engineers busy.I have not failed. I've just found 10,000 ways that won't work. ~Thomas EdisonComment
copyguy27e
Re: MPC3501 SC899
1. Firmware
2. Increase. Heap/Stack
3. AOF.. Auto Off...Turn off..( If machine goes to sleep and doesn't wake up fast enough failure to start software app occurComment
Re: MPC3501 SC899
You DO know that you're replying to a post that's 2.5 years old right?Comment
Re: MPC3501 SC899
also see this thread there is an issue printing from certain website.
Re: MPC3501 SC899
http://www.copytechnet.com/forums/ri...ror-codes.htmlComment
Re: MPC3501 SC899
Then again, I can't find where that is, so I'm probably full of crap. Sorry.Comment
Re: MPC3501 SC899
On most of these SC899's it's a PCL bug; I generally update the FCU, PCL and Network Support firmware as a set. We are also updating the Java on machines that do this, check the link:
On the MPCxx03 series with the embedded Java, you slap this onto an SD card, load it into the firmware slot, and wait for it to install. On older boxes, remove the Java card from the machine, load it into your laptop, and update it there.Comment
