Ricoh aficio 1075 a3 2nd copy wrinkle
  • georgereth
    • Jul 2009
    • 47
    Hi i have a problem with the a3 paper . I notice when i make dublex copies the paper is wrinkle when it comes out . At the 1 side its ok .
    Any ideas about that problem?
  • Jomama46
    • 2900
    paper is damp
    sigpic
    A+; Network +; PDI+
    • jummamaster
      • Mar 2009
      • 99
      check paper path also.
      Ricoh Error Codes
      Canon Error 5100
      Canon Error B200
      j
      c
      • vikrant_blaze
        Re: Ricoh aficio 1075 a3 2nd copy wrinkle
        clean pick up roller of the pickup unit, wrinkles on the paper are due to fuser unit, chq the bearings of top n bottom roller
        • lupi
          • Aug 2011
          • 102
          [Resolution]
          Replacing the fusing unit → Not resolved. Setting a shorter AOF time → Not resolved. Replacing the paper → OK, but replacing the paper is not possible due to customer request so responded with keeping the dehumidifying heater always ON using a harness.
          • xordi69
            • Jun 2010
            • 200
            clean duplex unit lloking for broken paper, it's press roller out of pm?
            check and clean fuser guiges
