SC-819 trouble. Functional porblem detected. its says in d manual that control board or option board has problem; i already checked. it can be cancel/reset? what are the other options to check and eliminate this trouble.. need ur inputs pls. thank u
RICOH aficio MP5000
Couple of things, make sure network support firmware is 5.19 and read attached tech bulletin in regards to improper shutdown causing this. Sometimes the fax unit can cause it (try removing and reboot without it). Also update all of the firmware. If all else fails then most likely you will have to replace the controller.
SC819 - Fatal kernel error
Due to a control error, a RAM overflow occurred during system processing.
One of the following messages was displayed on the operation panel.
0x6261 6261 6420 6469 7200 00 -> "bad dir"
0x696e 0x69742064 -> "init died"
0x766d 0x5f706167 -> "vm_pageout: VM is full"
554C UL (USB error)
---- Error in the OS
>System program defective
>Controller board defective
>Optional board defective
>Replace controller firmwareAttached Files -
we have faced this problem with almost 15 units. from the first time we encountered this we already updated all the firmawares of the other units(MP40005000) and educate our customer of the proper shutdown proc but to no avail. we replaced all the controller boards.Nobody is perfect..Comment
Just Manuals | The Internet's largest selection of manuals | Instant Downloads
Paul@justmanuals.comComment
fulltoner1
Re: RICOH aficio MP5000
I have expereinced one or two cases of replacing the touch panels but most of the times it has been because our client broke their pannels. But know they are telling me they have the same problem it happens on MP2510/AF3030 machine where the touch panel do not work properly. In my service mannual I saw two codes D009 1488 and D009 1498 and I wonder wich one of them is the one that I have to order to replace the damaged tocuh panel, does anybody know wich one should I order??Comment
We have been face this problem before, for several machines what we replace is the controller and there is one machine we replace interface board for BICU and Controller, it may accure also if the print/scan option is remove with out turning off the the device setting for usb and ethernet 5-985.Comment
for SC-819?Nobody is perfect..Comment
