Ricoh Aficio 270 Toner not automatically loading
  • dawnno1
    • Aug 2025
    I am using Ricoh Aficio 270.it is a big problem for me that the toner is not automatically loaded.i have to put the toner into drum unit manually after 100,150 copies.Now i want to supply the toner automatically.Kindly solve my problem
  • rsyarcia
    Hair Straightener Tech
    • 711
    you should be the one to solve your problem, we can only give ideas. first check the toner supply mechanism e.g the toner supply motor( check it using output check), mylar blades in the toner hopper etc.
    Nobody is perfect..
    • Jomama46
      • 2900
      Visually check the augers in the dev unit. They have a bad habit of breaking.
      sigpic
      A+; Network +; PDI+
      • mikadonovan
        • May 2008
        • 2931
        The mylars fall off inside the toner hopper and cause this problem. Time to replace it.
        NEVER ASSUME ANYTHING
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
          Just Manuals | The Internet's largest selection of manuals | Instant Downloads
          Paul@justmanuals.com
