mfp cl 7000
  • DINGO
    • 661
    mfp cl 7000
    Hi
    because i`m having a copy/print quality, in one mfp cl 7000 issue, i want clean to a laser unit including polygon motor.
    So, i never do it before, i work more with sharp copier, i need yours opinions, indications that can help me, how to disassemble it.
    thanks in advance
  • mikadonovan
    • May 2008
    • 2931
    Before you pull the laser unit, use the big blue toothbrush to clean the shield glasses and rule out a problem with a dev or drum unit. You have to be real careful when pulling the laser, or you'll get synch errors and/or screwed up prints upon reassembly.
    NEVER ASSUME ANYTHING
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • DINGO
        • 661
        thanks mikadonovan, i already do, every that you recomend.
