Mp 2000le sc 901 bicu ic burn.
  • kanglee
    • Feb 2011
    • 7
    Sc-901 when on machine nothing happen, when machine is ready , press the start button than only sc 901 appear and bicu ic burn.
  • TonerMunkeh
    Professional Moron
    • 3869
    Sounds like the mechanical counter is at fault. Have you changed it?
    Hit it.
    • Jomama46
      • 2900
      The wires from the counter are shorted, or if someone has been inside the counter it may be shorted.
      sigpic
      A+; Network +; PDI+
      • Herrmann
        • Jan 2006
        • 792
        would you mind to post a Photo of the burned area/chip? Have seen this here several Times, it was a SMD Power Transistor which seems to be too weak. I let it change against a stronger Type in a radio shack for about 20 EUR (28 $, i think), works like a charm since then.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • kanglee
          • Feb 2011
          • 7
          Thanks for the help I will check the counter. I have 3 machine having the same problem.
          • Jomama46
            • 2900
            3, wow
            sigpic
            A+; Network +; PDI+
            • TonerMunkeh
              Professional Moron
              • 3869
              Hmm.... anyone thinking counter rollback?
              Hit it.
              • Jomama46
                • 2900
                um humm
                sigpic
                A+; Network +; PDI+
                • kelvin3892
                  • Mar 2010
                  • 13
                  HI.....brother u can call this number 0123996900 ....he was the one expert in this model....
