jaming at 2018 d?
  • loverkoko
    • 35
    jaming at 2018 d?
    please my machine jaming at duplex unit at z please help me thanks
  • totoro
    • 568
    What's the jam code?
    Totoro
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • rsyarcia
        Hair Straightener Tech
        • 711
        check the duplex unit for any jammed paper, cleaN the sensors.
        Nobody is perfect..
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          Call a technician.
          • Robinh
            • 114
            Check for toner build up on the fuser guide plates. Makes sure the "one way" pin clutch that drives the duplexer is working correctly. Try and give a little more detail when you place your question. What's the jam code you are getting? When you say at Z, do you mean that the paper folds up like a fan? Look at the lead edge of your paper to see if it's catching on something. Good luck!
