Ricoh SPC232sf web server administrator password reset
  • D Colour
    • Oct 2008
    • 216
    [Misc] Ricoh SPC232sf web server administrator password reset
    Hi all!
    We have a problem with a Ricoh SPC232sf (machine is actually a Kyocera FS-C1020MFP)
    Our customer has change the password for the command center, then forgotten what it was. Now they can not save any changes they make.
    This machine is a rebadged Ricoh, so it is not the same cc as the rest of the Kyocera range. (see screenshots).
    Does anyone know of a way to reset the password back to factory - which is blank - or anything else for that matter?
    (I have also posted this in the Kyocera forum)
    Thanks!
    Everything that has a beginning, has an end.....
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Service manual sez:
    �� The "Reseller Default" menu can be entered directly at power-on. If you want to
    enter this mode directly, try the following procedure SPC 232SF Reset Password.
    1. Power OFF the unit.
    2. Power ON the unit while holding down the “Copy” key.
    3. Continue to hold down the “Copy” key until the display indicates “Factory Default
    Execute”.
    4. Release the “Copy” key.
    5. Press the Down Arrow, the display will change to “Factory Default Execute”.
    6. Press the OK key.
    7. The machine will display “Executing” and will perform a soft boot.
    8. When the unit returns to the ready condition, reboot by turing the Main Switch
    OFF and then ON.
    9. Set Language, Fax Number, Name and Country.
    10. Reboot the machine.
    I haven't used this procedure, so this may not reset the web interface password... So use at you're own risk.
    • D Colour
      • Oct 2008
      • 216
      Thanks cobiray, that worked a treat!
      • cobiray
        • Mar 2008
        • 1199
        Glad it worked!
