Aficio 650 developer spill problem
  • goldencup
    • Nov 2008
    • 366
    Hi I would like to seek help from you guys especially for those who have encountered this problem. I have a machine Aficio 650 and the problem is that the developer is always spilling . How do you solve this? What seems to be the problem? Thank you very much.
  • ccchuah
    • Mar 2009
    • 157
    replace the dv bushing and the paddle roller.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
      Paul@justmanuals.com
      • techsass
        • Dec 2010
        • 248
        I'm with ccchuah. It was a fairly common problem on the 550/650 series. Check behind the gears on the rear side of the DV unit & see if you've got DV buildup. If so do it quickly or you'll be replacing feed clutches. There was even a bulletin out about making a mylar to cover the clutches because of DV spills.
