i have a printer SD card. when i insert to aficio 3045 still no function printer appear. how to get this function? have any setting should i do?
how to install printer SD card on Ricoh 3045?
Is the SD card the correct one for that model?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
You're going to need the whole print scan kit, depending on the model of machine. I don't think these were available as an installable option, I think you ordered them as an SP or non-SP model from Ricoh. I'm assuming you'll need the SD card for the specific model you have, any additional memory, NIC card, USB or other printer input if not present on the machine. You will also likely have to enable the the printer input in SP5985.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
You're going to need the whole print scan kit, depending on the model of machine. I don't think these were available as an installable option, I think you ordered them as an SP or non-SP model from Ricoh. I'm assuming you'll need the SD card for the specific model you have, any additional memory, NIC card, USB or other printer input if not present on the machine. You will also likely have to enable the the printer input in SP5985.Comment
is this an original printer sd card or did you copy from an original sd card, copied ones dont work.Get your facts first, and then you can distort them as much as you please.Comment
ammarsaad
RE: how to install printer SD card on Ricoh 3045?
Please help me to get the software that contains the SD card of the machine DSm745 or 3045 . You can send it to my email : ammarsaadkamel@yahoo.com
or Tell me where I can get it Sincerely .Comment
Re: how to install printer SD card on Ricoh 3045?
or Tell me where I can get it Sincerely .' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
