In aficio 3245c , makes white scan ok but then lamp goes 5cmm out of place, and make copies with this 5cm margin white. No sc code...
Thanks and excuse my very bad english.
Does it happen from only the glass or also from the document feeder? Have you tried adjusting the starting scan position for the machine?
Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window. Michael Bolton: You and me both, man. That thing is lucky I'm not armed.
Also by the document feeder. I d'ont try to adjust scan position, but de unadjust is more than 5cm, but i will try it and say the result to you, thanks
Problem solved, its a bad connection of the sannerboard, thank you cobiray
Gracias por el interesClaudio, por lo visto era fallo de la connexion de la placa, repasaron soldaduras y ahora parece ok.
