MP C3500 Toner Problem
  • westpest
    • Jun 2011
    • 8
    Hi all
    machine continually calling for toner (black),replaced toner pump and tube,dev tank,pcu,toner end sensor and a different toner bottle to no avail,any suggestions welcome
    thanks
  • adween
    • Jun 2011
    • 23
    u use iriginal toner or compact toner?
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      • westpest
        • Jun 2011
        • 8
        Ricoh dealer everything is genuine
        • turbojetboy
          • Aug 2009
          • 279
          I have seen one like yours - it turned out that the dev had no drive due to worn fine tooth helical gear in rear of drive assy. was a slight noise and machine just stuck on toner loading. Had to replace entire drive assy - not fun but all worked fine after,
          • CANCOUNTRY TECH
            • Aug 2008
            • 114
            Replace the dev clutch take the rear cover off youll be able to see the clutch not engaging had a couple of these
            • butcher
              • 48
              Does the black toner bottle rotate? IF not it could be the toner supply clutch
              • rsyarcia
                Hair Straightener Tech
                • 711
                this is right we already experienced this problem, the dev't clutch is defective. what we did is replace the dev't clutch from cyan dev't clutch just to isolate the problem then the machine worked fine.
                Nobody is perfect..
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  Sounds like the Toner sensor is gone in the PCU dev tank.
                  If you are using SPC811 units and swapping the toner sensor then try a standard PCU unit for a test.
                  I have had this fault and no SC code was display until I swapped the faulty PCU to a completely different machine. Only then did the faulty PCU generate an SC code.
                  • Polo-022
                    • Sep 2007
                    • 484
                    Are there any copy quality issues (blank prints for ex.) when dev. clutch fails, or not?
                    • rsyarcia
                      • 711
                      yes there is a copy quality problem blank copy with black, while the machine continouosly ask for toner it will not be distributed in the dev't unit since the clutch is not working. you can verify that by removing the pcdu of the machine(e.g black) the opening of the dev't unit is full of toner.
                      Nobody is perfect..
                      • Polo-022
                        • Sep 2007
                        • 484
                        Thanks a lot for the feedback "rsyarcia"..
