SD printer ricoh 3045 and Gestetner DSM 745
  • adween
    • Jun 2011
    • 23
    i just want to know the different sd printer card Gestetner DSM 745 and ricoh aficio 3045. can i use ricoh 3045 printer SD to Gestetner DSM 745. this machine are same but different model. if i use printer SD ricoh 3045 to Gestetner DSM 745, Can its work? pls, i need your advise. i'm still learning about this model.
  • eurokris
    • 120
    same .can use.
    • adween
      • Jun 2011
      • 23
      i try to use it but cant detect. i enable already sp mode nic and usb. but after that my machine restard and appear SC 816. when i remove the sd card machine ok can use. have any idea? many times i try but its not work. have any setting shuld i do?
      Originally posted by eurokris
      same .can use.
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        Repeated post read you first.
        • mdtrinh
          • Aug 2010
          • 68
          Yes, It can be used on Gestetner 745 (already tried).
          It sounds like missing memory module, 128MB, PC2100.
