SC 992 and 670 codes
  • Blazer1087
    • 195
    Hi everyone, could use your help again. I had a call on an aficio 2022 that was dead. She said it started with a sc 670 code and when she turned it of and back on it never came back on. I replaced the sbcu board first, no change. I replaced the power supply board, now it comes on but displays a sc 992 code. Turning it of with the op panel switch and back on turns off the wrench and code but stays on please wait mode for about 5 min and finally changes to sc 670. Tomorrow I will reinstall the firm ware to see if that takes care of it, am I going in the right direction or am I missing something? Thanks for any help
  • Fearless V K
    • 620
    unplug the HDD if it has one. see if it works then. if so... bad HDD
    Don't take that toner with me!
    • Blazer1087
      • 195
      HDD is not installed, no print or fax either, just plain old copier.
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Have you tried a *# reboot? Does this still have a memory DIMM even though it's a walkup only?
        • Blazer1087
          • 195
          Nope, no memory. Its a no frills unit !!
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
            Paul@justmanuals.com
            • Jomama46
              • 2900
              clean the contacts of the DIMM and prepare for a controller or SBCU replacement.
              sigpic
              A+; Network +; PDI+
              • Blazer1087
                • 195
                It doesnt have a dimm, allready replaced the sbcu board, and the only controller I have is for a 1027....will it work for a 2022 if I exchange the NVRAM?
                • Jomama46
                  • 2900
                  nope, two different animals.
                  sigpic
                  A+; Network +; PDI+
                  • Jomama46
                    • 2900
                    Da Goose says, SBCU or Controller
                    sigpic
                    A+; Network +; PDI+
                    • Blazer1087
                      • 195
                      No HDD installed, guess that narrows it down. You dont think reinstalling the firmware will help?
                      • Jomama46
                        • 2900
                        No, but for the price of a controller, its worth a shot.
                        sigpic
                        A+; Network +; PDI+
                        • Blazer1087
                          • 195
                          Thank you, Ill let you know how it turns out.
                          • Blazer1087
                            • 195
                            I found a used controller board and that did the trick, thanks. I dont know why this copier was dead to begin with unless both the controller and ps boards had a problem, but the account is happy know and that means Im happy....time for a drink!
                            • Jomama46
                              • 2900
                              Glad you got it sorted out.
                              sigpic
                              A+; Network +; PDI+
