Today I was asked to help setup an MP2000 for scanning to folder, by a client who had obtained the machine elsewhere. I've setup several of the MP series before, although I don't think this one in particular.
Once I logged into the WIM and clicked on the address book, it was obvious that something was wrong. The only available options were basically "name" and "fax number". There was no space to enter any email settings folder authentication, path, or otherwise -very strange.
I was able to configure the email settings under the configuration button in the WIM, and then manually enter an email address via the control panel of the machine, and successfully send an email, but this is certainly not ideal and doesn't solve the "scan to folder" issue.
I actually had the firmware for this machine with me, and updated all features, and did a "memory all clear" too.
Machine is otherwise fine for print, fax, etc.
Anybody seen this type of thing before? I'm figuring it's a board problem of some sort, but it's just a strange one.
