Scan to Folder with a Windows 7 OS
  • Vioksrall
    • Sep 2010
    • 84
    I followed the procedure given by the NRGI post on how to configure SCAN TO FOLDER with a WINDOWS 7 OS but still it don't work. Am I missing something? Does anyone had experience with the same problem? Please help. Thanks.
  • mojorolla
    The Wolf
    • 2671
    If the PC has Windows Live Essentialson it, remove it. Have seen this a few times now. Also, do not put the destination folder on the desktop; this too can cause issues.
    • df3036
      • 109
      Depending on the model, you will need to do a firmware update....
      Kittens give Morbo gas.
      A+, Network+, Server+, PDI+
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        You might need local login credentials to access the folder. I've had a few that I needed to create generic scan accounts on the local machines to have access to the folders.
        • Gift
          • Mar 2011
          • 2456
          that's correct - microsoft did some changes with the SMB protocal that's why you might have issues with older models/fw versions. I'm afraid that some discontinued products won't work with scan-to-folder/win7 at all (you can still use scan-to-ftp then).
          • Scoop
            Which machine are you trying to scan from?
            • Vioksrall
              • Sep 2010
              • 84
              I was configuring MP4000 machine.
              • df3036
                • 109
                Firmware fix for this. Just a quick clip... Network Support...
