mpc2050 feed noise
  • fritzyas
    • Jul 2011
    • 73
    Re: mpc2050 feed noise
    Originally posted by tonnerboy
    As already stated, your problem is with the tension spring.
    My suggestion is: take the spring from the separation pad and put the machine to work. Do not worry it will not jam. When you manage, go to the client and put a new spring.
    I know I'll hear laughing (has happened before). Believe me it work fine.
    I did this but still there was sound. As long as the same friction pad and feed roller were used then there will be sound. That's why there are modifications made.
    • mustdie
      • Jul 2011
      • 26
      Replace friction pad with A2018 model..I mean not hole unit friction pad but only rubber(i dont know what it call)..hehe
