interface to card reader
  • dckm
    • 79
    Any info on connections?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Which MFP, Card Reader, and application are you referring to?
    • dckm
      • 79
      Blackboard cards reader. Just want to enable copier with card swipe. What are the connection pinouts?
      • Jomama46
        • 2900
        The manufacturer should have provided you with a harness or at least a schematic. This does not bode well if you ever need support. Most of the color machines will require a certain card as an interface.
        sigpic
        A+; Network +; PDI+
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          All of my resent experience with any code systems have needed the appropriate harness for the equipment it's to be installed on. I.E. if you're installing it on an MPC5501, you will need to order the appropriate harness from the card reader company for the MPC5501.
          If you're installing this on an existing reader system just give the manufacturer a call, check their website for a phone number. My experience has been pretty good with getting help with setting them up.
