Sc350 appeared on 2035 after completing copies operations
  • akbareshghi
    • Sep 2010
    • 261
    Sc350 is generated when the operation of coping is finished regardless of the number of copies
    I go to service mode and I performed 3001-02 (ID Sensor Initialization) but before appearing the message of complete , the SC350 error code is generated.
    If I copy the originals with this situation , do it create problem for laser.
    My current setting of 3001-01= ID Sensor PWM Setting= 255
    My reading of 3103 are the following :
    Vsg (Drum Surface Output)= 1.31 v
    Vsp (Pattern Output)=0
    Vpdp (Immediate Post-Pattern Output)=0
    Vsm/Vsg (Immediate Grayscale Post-Pattern Output)=0
    My guessed causes of this error:
    1- High voltage power supply board
    2- My wrong setting of TD sensor
    Thank you for one permanent solution
    Color printing with lowest cost per page is my love.
  • infsergey
    • Apr 2011
    • 14
    Background on copies there? Safety glass laser clean?
    • akbareshghi
      • Sep 2010
      • 261
      I removed the pcu unit and cleaned from bottom the ID sensor with brush and cotton
      then i reinserted pcu unit and go to service manual and perform 3001
      then sc350 does not appeared and my problem is solved
