sc error code 819/878 ricoh af mp 3350b
  • jhunsenpab
    • Aug 2025
    hello guys..i want to ask your technical advice for error code (sc-819..sometimes sc-878)i encounter with this problem for this ricoh af mp3350..pls..advice..
  • jonhiker
    • 661
    Both of those codes point to a bad controller board, try replacing the board.
    • Jomama46
      • 2900
      You can clean the DIMM contacts but I think probably jonhiker is correct
      sigpic
      A+; Network +; PDI+
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • jummamaster
          • Mar 2009
          • 99
          Kernel Mismatch, Download Firmware again
          SC819
          Ricoh Error Codes
          Canon Error 5100
          Canon Error B200
          j
          c
          • MGUNGU
            • May 2008
            • 12
            Re: sc error code 819/878 ricoh af mp 3350b
            just changed the controller board and it worked
            • rsyarcia
              Hair Straightener Tech
              • 711
              before raplacing the controller board check the hd also we had an experience with sc 819 and when we dsiconnected the HD the m/c worked.
              Nobody is perfect..
              • TonerMunkeh
                Professional Moron
                • 3865
                Some of these Russian-C5's don't come with HDD's, believe it or not. 819 and 870 on these buggers is usually a fried controller. The Alex suffers from the same problems too.
                Hit it.
                • rsyarcia
                  • 711
                  ok.
                  Nobody is perfect..
