aficio 1035 recycled toner stockup
  • cleardata
    • Jul 2011
    • 137
    hi, i have another problem with my ricoh aficio 1035. i always clean the recycling part of the drum unit after 5,000 copies because of the toner stock up which causes dirt to the copies. i already lowered the temperature of the fusing and even changed 2209 to 150 but it didnt solve the problem. please help. i keep on cleaning it every week.
  • Eric1968
    • 2458
    Re: aficio 1035 recycled toner stockup
    Could be a Cleaning Blade problem. How many has the PCU done?
    • cleardata
      • Jul 2011
      • 137
      i havent checked the number of copies it has copied but the cleaning blade still looks ok since it doesnt have lines on the copy. il try replacing the cleaning blade. please explain why its a cleaning problem? i want to learn more.
      thank you.
      • TonerMunkeh
        Professional Moron
        • 3865
        If you're getting copy quality issues a lot on these machines, do a FULL PCU rebuild: drum, charge roller, cleaning roller and blade. Might not hurt to replace the developer as if the dev's on it's way out, it could be overtoning. That should sort you out. Also, are you using OEM toner? The Adonis is a dirty bugger at the best of time, won't do it any favours if you're not feeding it premium carbon black.
        Hit it.
        • teebee1234
          • Jul 2008
          • 1670
          Sounds like the toner collection coil behind the blade is not turning, allowing the buildup. The gear on the end of the coil is most likely rounded out on the end of the shaft or the coil itself broke off.
          • Eric1968
            • 2458
            To be sure, like Teebee said, replace the whole PCU. Then you should be out of trouble.
            • Masterchief
              • Apr 2011
              • 280
              dont forget to also clean the mag rollers on the development unit fully, this eliminates 80% of dirty copies....
              sigpic
              • cleardata
                • Jul 2011
                • 137
                hi thank you for your solutions. i have more than 20units of aficio 1035 and 2035 and most of it has the same problem of toner stockup. based on my observation the toner builds up on the metal paddle (dont know the correct part name for it) behind the blade and it doesnt go to the recycling spring so it can go back to the dev unit. the gears are ok but im not using oem toner. im using what they call class A replacement toner. when i open the plastic cover on top where the drum unit handle is attached, there are less toner on the recycling spring but the metal paddle is overloaded with toner and some toner are a little bit hardened already. i keep on servicing it weekly. too much time spent on servicing this problem. causes dirt on the copy and sc350.
                • sandmanmac
                  • 3981
                  20 units all doing the same thing and compatible toner? Thats' where I'd start, a complete PCU rebuild (or better yet new PCU), and OEM toner only. I would never use a generic toner in any Ricoh machine, you're just asking for headaches like this.
                  • sharpmind
                    • Sep 2009
                    • 478
                    If the toner builds up in the recycling section, clean it properly by removing the toner collection coil behind the toner mylar.Paper dusts accumulate at the end of the toner collection coil thus blocking the recycled toner.(see attached picture)
                    Is the toner mylar in the recycling section still good?
                    • rsyarcia
                      Hair Straightener Tech
                      • 711
                      [QUOTE=teebee1234;229890]Sounds like the toner collection coil behind the blade is not turning, allowing the buildup. The gear on the end of the coil is most likely rounded out on the end of the shaft or the coil itself broke off.[/QUOTE
                      agree with teebee and i want to add this try turning the collection coil manually if it is turning freely , if not check for the bushing.
                      Nobody is perfect..
                      • cleardata
                        • Jul 2011
                        • 137
                        yes the toner mylar is still ok. i cleaned the toner collection coil and the toner mylar including all the gears. it seems that the toner in the toner mylar section doesnt transfer to the toner collection coil so it can go back to the dev unit. thank you for the picture.
                        im quite confused about the name of the parts. collection coil for me is the long spring while the toner mylar is the metal with an attached plastic like an acetate. sorry for my ignorance.
                        i even replaced all the grears and plastic bushing at both ends of the toner mylar but it was not the solution.
                        • mackattk
                          • Jun 2011
                          • 5
                          Remove PCU end cap (4 screws). pull the metal piece at the end of the recycle coil out .5 inch and remove the fibers or hairs from the coil. Filbers,paper dust and hair will not allow the recyced toner to pass.
                          • iMind
                            Vacuum Cleaning Expert
                            • Mar 2008
                            • 1116
