Tracking of FAX RX and TX for MPC 3001
  • fritzyas
    • Jul 2011
    • 73
    is there a way that we can track a sent fax and received fax documents. our customer wants this setting to know what are his employees sending and receiving,Is this possible?thank you again for your support
  • Eric1968
    • 2458
    Re: Tracking of FAX RX and TX for MPC 3001
    The only thing you can track is when the machine sends a fax or receives one, and how many pages. The contents of incoming and outgoing faxes can not be tracked, as far as I know.
    • copyman20
      • 207
      for tracking incoming. turn on fax rx forwording to a folder. to track outbounds, go to fax features-send settings tab. turn on backup tx files. point it to a folder.
      Good Luck
      • fritzyas
        • Jul 2011
        • 73
        tnx eric and copyman
        • z_ming
          • Jul 2011
          • 31
          i've been experiencing the same issue.my customer want to track everthing from the MFP (such as print,scan,fax,copy). is there any solution to solve this issue
          • Ollie1981
            Toner Monkey
            • Mar 2008
            • 418
            They want to track how many clicks each user does? Or they actually want to see the contents of the print/copy/scan/fax jobs?
            I suggest it would probably be easier for them to just lock out the machine via user codes or similar to prevent unauthorised usage because there's nothing (for Ricoh machines at least) that I know of that actually tracks the content of jobs going to and from the machine. Something about a customer wanting to go to that kind of lengths suggests to me that they don't trust their staff, it's a bit Big Brother-ish.
