Ricoh MP161spf
  • THINKINK01
    • Mar 2009
    • 31
    Ricoh MP161spf
    Unit has less than 100K prints. Copier/scanner/fax works flawlessly. Whenever used as a printer the display will say that a paper mismatch has occured, at this point you can select the button to continue or cancel the job.
    It doesn't matter what is the paper size selection you make in printer preferences, in the software or in the network driver. The end result is always the same. The paper being used in the bypass and in tray 1 is 8.5x11 portrait. Tray 2 isn't installed.
    Any insight appreciated.
  • sharpmind
    • Sep 2009
    • 478
    Re: Ricoh MP161spf
    change the paper size setting in the user tools.
    • johnyb
      • Feb 2011
      • 167
      Re: Ricoh MP161spf
      SUB Paper size needs turning on!
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 418
        Re: Ricoh MP161spf
        User Tools - Printer Features - System Settings
        Set Sub Paper Size to "Auto"
        Set Auto Continue to "Immediate"
        I think you'll find that makes the problem go away
